Peerless' PRG Precision Gear Projector Mount is changing the way image alignment is carried out. The patent-pending precision gear design provides exact tilt and roll image positioning with a simple turn of a knob. Once the precision gear is set to the desired position it stays securely in place. It will not shift during projector maintenance, bulb replacement, and will not loosen or change alignment due to vibration, accidental bumping etc. With Peerless' PRG Precision Gear Projector Mount the installer sets it and forgets it.
- Peerless PRG Precision Gear Projector Mount with Spider Universal Adapter PRG-UNV-W mounting component - Tilt & Swivel - for projector - white
- Product Type
- Mounting component (Tilt & Swivel)
- Mounting Components
- Ceiling mount, spider arms
- 1.3 kg
- Recommended Use
- Projector
- Max Load Weight
- 22.6 kg
- Material
- Aluminium alloy
- White
- 1.3 kg
- Material
- Aluminium alloy
- White
AV Furniture
- Design
- Tilt & Swivel
- Recommended Use
- Projector
- Max Load Weight
- 22.6 kg
- Quick release, scratch-resistant
Peerless-AV Peerless PRG Precision Gear Projector Mount with Spider Universal Adapter PRG-UNV-W (White)
