Peerless-AV Peerless PRG Precision Gear Projector Mount with Spider Universal Adapter PRG-UNV (Black)
Quicklinx: 7HN4WS00 Mfr#: PRG-UNV
Hurry, only 1 left in stock!
£125.91 ex VAT
£151.09 inc VAT
Peerless' PRG Precision Gear Projector Mount is changing the way image alignment is carried out. The patent-pending precision gear design provides exact tilt and roll image positioning with a simple turn of a knob. Once the precision gear is set to the desired position it stays securely in place. It will not shift during projector maintenance, bulb replacement, and will not loosen or change alignment due to vibration, accidental bumping etc. With Peerless' PRG Precision Gear Projector Mount the installer sets it and forgets it.
Peerless PRG Precision Gear Projector Mount with Spider Universal Adapter PRG-UNV mounting component - Tilt & Swivel - for projector - black
Mounting component (Tilt & Swivel)
Mounting Components
Ceiling mount, spider arms
1.3 kg
Recommended Use
Projector
Max Load Weight
22.6 kg
Material
Aluminium alloy
Dukane ImagePro 6660WUSSB
1.3 kg
Material
Aluminium alloy
AV Furniture
Mounting component
Mounting Components
Design
Tilt & Swivel
Recommended Use
Projector
Max Load Weight
22.6 kg
Quick release, scratch-resistant
Brand: Peerless-AV
