Peerless-AV Peerless PARAMOUNT Ceiling/Wall Projector Mount with Adjustable ExtensionPPA-S-mounting kit (Silver)
Quicklinx: 7MTKWS00 Mfr#: PPA-S
Allows a projector to be ceiling or wall mounted. Adjustable extension - 324-452mm (ceiling), 253-357mm (wall).
Peerless PARAMOUNT Ceiling/Wall Projector Mount with Adjustable Extension PPA-S - mounting kit - Tilt & Swivel - for projector - silver
Mounting kit (Tilt & Swivel)
Mounting Components
Extension column, ceiling plate, mounting adapter, horizontal adjuster
Adjustable Width
16.5-42 cm
Adjustable Depth
16.5-42 cm
Adjustable Height
32.4-45.2 cm
1.4 kg
Recommended Use
Projector
Max Load Weight
22.6 kg
Material
Cold-rolled steel
Silver
5-year warranty
Adjustable Width
16.5-42 cm
Adjustable Depth
16.5-42 cm
Adjustable Height
32.4-45.2 cm
1.4 kg
Material
Cold-rolled steel
Silver
AV Furniture
Mounting kit
Mounting Components
Design
Tilt & Swivel
Recommended Use
Projector
Max Load Weight
22.6 kg
Scratch-resistant
Limited warranty - 5 years
