Pre-assembled Modular Series Ceiling Kit including the following: 1 x MOD-CPC cathedral ceiling plate, 1 x MOD-P150 1.5m extension pole, 1 x MOD-FPMS single screen flat panel mount, 1 x MOD-UNL large universal adaptor.
Effortless adjustability
Designed with a tilt feature, this mounting kit allows for easy angle adjustments, ensuring the perfect viewing experience from any position. -
Versatile placement
Ceiling-mountable design offers a unique solution for optimizing space and enhancing room aesthetics, making it ideal for both home and office settings. -
Robust support
Capable of supporting flat panels up to 60 kg, this mount kit combines reliability and strength, providing peace of mind for securing valuable displays.
- Peerless Modular Series Flat Panel Ceiling Mount Kit mounting kit - for flat panel - black
- Product Type
- Mounting kit - ceiling mountable
- Mounting Components
- Ceiling plate, bracket, extension pole
- Adjustments
- Tilt
- Recommended Use
- Flat panel
- Recommended Display Size
- Up to 75"
- VESA Mounting Interface
- 600 x 400 mm
- Max Load Weight
- 60 kg
- Black
- Black
AV Furniture
- Mounting kit
- Recommended Use
- Flat panel
- Placing / Mounting
- Ceiling mountable
- 600 x 400 mm
- Up to 75"
- Adjustments
- Tilt
- Max Load Weight
- 60 kg
- Rotating, lockable
