The Peerless Modular Series has been introduced as a mounting system with just over a dozen components that combine to meet virtually any installation application.
Robust support
Designed specifically for LCD displays and projectors, the Peerless Modular Series U-Bolt Accessory offers a solid and secure mounting solution. Its robust design ensures your equipment remains safely in place, providing peace of mind in any installation environment. -
High capacity
With a maximum load weight of 120 kg, this mounting component is capable of supporting even the heaviest of displays or projectors. This high capacity makes it a versatile choice for a wide range of AV setups, from classrooms to conference rooms.
- Peerless Modular Series U-Bolt Accessory mounting component - for LCD display/projector - black
- Product Type
- Mounting component
- Packaged Quantity
- 2 (specifications are for single item)
- Mounting Components
- U-bolt
- 12.5 cm x 2.5 cm
- Recommended Use
- LCD display/projector
- Max Load Weight
- 120 kg
- Black
- Designed For
- Modular Series Cathedral Ceiling Plate, Heavy Duty Flat Ceiling Plate
- Packaged Quantity
- 12.5 cm
- 2.5 cm
- Black
AV Furniture
- U-bolt
- Recommended Use
- Max Load Weight
- 120 kg
- Designed For
- Peerless Modular Series Cathedral Ceiling Plate, Heavy Duty Flat Ceiling Plate
