Peerless' Security Lockable Mounts offer the next level of security within the wall mount range with a secure locking bar and provided padlock.
Secure mounting
The Peerless Flat-to-Wall Security Locking Mount is designed with a lockable feature, ensuring your flat panel remains securely attached to the wall, providing peace of mind in public or high-traffic areas. -
Versatile compatibility
Accommodating a wide range of display sizes from 32" to 58", this mounting kit is versatile enough to support various flat panel models, making it an ideal choice for both home and commercial settings. -
Robust design
With a maximum load weight of 79 kg and a flat panel mount interface of 700 x 400 mm, the Peerless Flat-to-Wall Security Locking Mount is built to hold substantial weight, ensuring your display stays safely in place.
- Peerless Flat-to-Wall Security Locking Mount PFLP650 mounting kit - for flat panel - black
- Product Type
- Mounting kit - wall-mountable
- Mounting Components
- Wall mount
- 50.8 cm x 4.3 cm x 71.5 cm
- Recommended Use
- Flat panel
- Recommended Display Size
- 32" - 58"
- VESA Mounting Interface
- 700 x 400 mm
- Max Load Weight
- 79 kg
- Black
- 50.8 cm
- 4.3 cm
- 71.5 cm
- Black
AV Furniture
- Mounting kit
- Wall mount
- Recommended Use
- Flat panel
- Placing / Mounting
- Wall-mountable
- 700 x 400 mm
- 32" - 58"
- Max Load Weight
- 79 kg
- Lockable
