Peerless-AV Peerless  Portrait Locking Flat Wall Mount For 32-58" Flat Panel Scre
Quicklinx: 7MXRWS00 Mfr#: PFLP650
Hurry, only 1 left in stock!
£156.81 ex VAT
£188.17 inc VAT
Peerless' Security Lockable Mounts offer the next level of security within the wall mount range with a secure locking bar and provided padlock.
  • Secure mounting
    The Peerless Flat-to-Wall Security Locking Mount is designed with a lockable feature, ensuring your flat panel remains securely attached to the wall, providing peace of mind in public or high-traffic areas.
  • Versatile compatibility
    Accommodating a wide range of display sizes from 32" to 58", this mounting kit is versatile enough to support various flat panel models, making it an ideal choice for both home and commercial settings.
  • Robust design
    With a maximum load weight of 79 kg and a flat panel mount interface of 700 x 400 mm, the Peerless Flat-to-Wall Security Locking Mount is built to hold substantial weight, ensuring your display stays safely in place.
Peerless Flat-to-Wall Security Locking Mount PFLP650 mounting kit - for flat panel - black
Mounting kit - wall-mountable
Mounting Components
Wall mount
50.8 cm x 4.3 cm x 71.5 cm
Recommended Use
Flat panel
Recommended Display Size
32" - 58"
VESA Mounting Interface
700 x 400 mm
Max Load Weight
79 kg
50.8 cm
4.3 cm
71.5 cm
AV Furniture
Mounting kit
Mounting Components
Wall mount
Recommended Use
Flat panel
Placing / Mounting
Wall-mountable
700 x 400 mm
32" - 58"
Max Load Weight
79 kg
Lockable
Brand: Peerless-AV
