Peerless-AV Peerless  Locking Tilt Wall Mount For 15-37" LCD Screens, Vesa 2x2
Quicklinx: 7MXSWS00 Mfr#: PTL635
£135.60 ex VAT
£162.72 inc VAT
Peerless' Security Lockable Mounts offer the next level of security within the wall mount range with a secure locking bar and provided padlock.
  • Secure mounting
    The Peerless Tilting Security Locking Mount is designed with a lockable feature, ensuring your flat panel remains securely in place. Ideal for public or high-traffic areas, this mount provides peace of mind by preventing unauthorized removal or adjustment of your display.
  • Versatile compatibility
    Accommodating a wide range of flat panel sizes from 15" to 37", this mounting kit is versatile enough for various display needs. With a flat panel mount interface of 200 x 200 mm, it ensures a good fit for your display, enhancing stability and viewing experience.
  • Enhanced viewing experience
    Featuring tilt adjustments, the Peerless Tilting Security Locking Mount allows for optimal viewing angles. Whether you're aiming to reduce glare or simply adjust the display to suit viewer height, this mount provides the flexibility needed for an improved viewing experience.
Peerless Tilting Security Locking Mount PTL635 - mounting kit - for flat panel - black
Mounting kit - wall-mountable
Mounting Components
Tilt wall mount
31.9 cm x 6.6 cm x 26 cm
Adjustments
Tilt
Recommended Use
Flat panel
Recommended Display Size
15"-37"
VESA Mounting Interface
200 x 200 mm
Max Load Weight
56 kg
31.9 cm
6.6 cm
26 cm
AV Furniture
Mounting kit
Mounting Components
Tilt wall mount
Recommended Use
Flat panel
Placing / Mounting
Wall-mountable
200 x 200 mm
15"-37"
Adjustments
Tilt
Max Load Weight
56 kg
Lockable
Brand: Peerless-AV
