Peerless' Security Lockable Mounts offer the next level of security within the wall mount range with a secure locking bar and provided padlock.
Versatile display compatibility
Designed to support flat panels ranging from 37" to 75", the Peerless PFL650 mounting kit ensures a perfect fit for a wide array of display sizes, making it an ideal choice for both home and commercial settings. -
Enhanced security features
With its lockable design and a locking bar included, the Peerless PFL650 mounting kit offers an added layer of security, ensuring that your flat panel remains safe and securely mounted at all times. -
Easy adjustment
Featuring a landscape function and lateral shift accessory, this mounting kit allows for effortless adjustment and positioning of your flat panel, ensuring optimal viewing angles and a tailored entertainment or presentation experience.
- Peerless PFL650 mounting kit - for flat panel - black
- Product Type
- Mounting kit
- Mounting Components
- Lateral shift accessory, locking bar
- 78.1 cm x 4.3 cm x 42 cm
- Recommended Use
- Flat panel
- Recommended Display Size
- 37"-75"
- VESA Mounting Interface
- 700 x 400 mm
- Max Load Weight
- 79 kg
- Black
- 78.1 cm
- 4.3 cm
- 42 cm
- Black
AV Furniture
- Mounting kit
- Recommended Use
- Flat panel
- 700 x 400 mm
- 37"-75"
- Max Load Weight
- 79 kg
- Landscape function, lockable
