Peerless' security lockable mounts offer the next level of security within the wall mount range with a secure locking bar and provided padlock.
- Peerless Flat-to-Wall Security Locking Mount PFL635 mounting kit - for flat panel - black
- Product Type
- Mounting kit - wall-mountable
- Mounting Components
- Wall mount
- 31.9 cm x 3 cm x 26 cm
- Recommended Use
- Flat panel
- Recommended Display Size
- 15"-37"
- VESA Mounting Interface
- 200 x 200 mm
- Max Load Weight
- 56 kg
- Black
- 31.9 cm
- 3 cm
- 26 cm
- Black
AV Furniture
- Mounting kit
- Wall mount
- Recommended Use
- Flat panel
- Placing / Mounting
- Wall-mountable
- 200 x 200 mm
- 15"-37"
- Max Load Weight
- 56 kg
- Lockable
