No wall space? No problem. This VESA compliant LCD ceiling mount gets the TV up easily and offers an incredible range of viewing options. Installation is made simple with its one-, two-, three- design. Simply attach the ceiling plate, attach the adapter to the screen and hook-on the TV on to the mount - Done. This LCD TV mount delivers the ultimate in positioning options with its tilt and infinite swivel options for that ultimate flat panel viewing experience.
- Peerless PARAMOUNT LCD Ceiling Mount PC932B - mounting kit - Tilt & Swivel - for LCD TV - black
- Product Type
- Mounting kit (Tilt & Swivel)
- Mounting Components
- Extension column, ceiling plate, tilt bracket, mounting adapter
- 16.5 cm x 16.5 cm
- Adjustable Height
- 35-55.6 cm
- 2.3 kg
- Recommended Use
- LCD TV
- Recommended Display Size
- 15"-37"
- VESA Mounting Interface
- 100 x 100 mm, 75 x 75 mm, 200 x 200 mm, 200 x 100 mm
- Material
- Cold-rolled steel
- Black
- 5-year warranty
- 16.5 cm
- 16.5 cm
- Adjustable Height
- 35-55.6 cm
- 2.3 kg
- Material
- Cold-rolled steel
- Black
AV Furniture
- Mounting kit
- Design
- Tilt & Swivel
- Recommended Use
- LCD TV
- 15"-37"
- Scratch-resistant
- Limited warranty - 5 years
