Allows a projector to be ceiling or wall mounted. Adjustable extension - 324-452mm (ceiling), 253-357mm (wall).
- Peerless PARAMOUNT Ceiling/Wall Projector Mount with Adjustable Extension PPA-W - mounting kit - Tilt & Swivel - for projector - white
- Product Type
- Mounting kit (Tilt & Swivel)
- Mounting Components
- Extension column, ceiling plate, mounting adapter, horizontal adjuster
- Adjustable Width
- 16.5-42 cm
- Adjustable Depth
- 16.5-42 cm
- Adjustable Height
- 32.4-45.2 cm
- 1.4 kg
- Recommended Use
- Projector
- Max Load Weight
- 22.6 kg
- Material
- Cold-rolled steel
- White
- 5-year warranty
- Adjustable Width
- 16.5-42 cm
- Adjustable Depth
- 16.5-42 cm
- Adjustable Height
- 32.4-45.2 cm
- 1.4 kg
- Material
- Cold-rolled steel
- White
AV Furniture
- Mounting kit
- Design
- Tilt & Swivel
- Recommended Use
- Projector
- Max Load Weight
- 22.6 kg
- Scratch-resistant
- Limited warranty - 5 years
