The Paramount series wall mounts provide versatile and multi-functional features. With PA762, extend the display up to 21.32" (542mm) or fully-retract it to just 3.00" (76mm) from the wall for the perfect viewing angle. The Hook-and-Hang system offers easy, one-person installation of the display. A ratcheting handle provides locking tilt capability for quick adjustments to the amount of tilt, reducing glare and optimizing the viewing angle. Integrated cable management protects, contains and conceals cables for a clean installation.
Versatile positioning
With pan capabilities ranging from -45° to 45° and a tilt range of -5° to 15°, this mounting kit offers versatile positioning options for the optimal viewing experience. -
Broad compatibility
Designed to support flat panels ranging from 39" to 90" and capable of handling up to 68 kg, this mount is suitable for a wide array of display sizes, ensuring broad compatibility. -
Streamlined setup
Featuring integrated cable management and a comprehensive mounting component set, the installation process is streamlined, resulting in a clean and clutter-free setup.
- Peerless-AV Paramount PA762 mounting kit - for flat panel - gloss black
- Product Type
- Mounting kit - wall-mountable
- Mounting Components
- Articulating wall mount
- Tilt
- -5° to 15°
- Pan
- -45° to 45°
- 9.56 kg
- Recommended Use
- Flat panel
- Recommended Display Size
- 39"-90"
- VESA Mounting Interface
- 200 x 100 mm, up to 400 x 400 mm
- Max Mounting Pattern Size
- 438 x 329 mm
- Max Load Weight
- 68 kg
- Gloss black
- 9.56 kg
- Gloss black
AV Furniture
- Mounting kit
- Recommended Use
- Flat panel
- Placing / Mounting
- Wall-mountable
- 438 x 329 mm
- Cable Management
- Integrated cable management
- 39"-90"
- Tilt
- -5° to 15°
- Pan
- -45° to 45°
- Max Load Weight
- 68 kg
