Peerless-AV Modular Series Single Screen Mount - Black
Quicklinx: 73JTWS00 Mfr#: MOD-FPMS
Accessory Type: Mount
£59.74 ex VAT
£71.68 inc VAT
The Peerless Modular Series has been introduced as a mounting system with just over a dozen components that combine to meet virtually any installation application.
  • Versatile display compatibility
    Designed to support a wide range of display sizes from 10" to 65", this mount offers flexibility for different screen dimensions, making it a suitable choice for various flat panel displays.
  • Effortless cable management
    Equipped with a Cable Management System (CMS), it ensures a clean and organized appearance by neatly concealing cables, enhancing the overall aesthetic and safety of your space.
  • Advanced adjustability
    Features such as tilt and rotation capabilities allow for optimal viewing angles and orientation, ensuring a comfortable and customizable viewing experience for any application.
Peerless Modular Series Single Screen Mount mounting component - for flat panel - black
Mounting component
Mounting Components
Mount
13 cm x 8.7 cm x 13 cm
Adjustments
Tilt
Recommended Use
Flat panel
Recommended Display Size
10"-65"
Max Load Weight
100 kg
13 cm
8.7 cm
13 cm
AV Furniture
Mounting component
Mounting Components
Mount
Recommended Use
Flat panel
Cable Management
10"-65"
Adjustments
Tilt
Max Load Weight
100 kg
Rotating
Brand: Peerless-AV
