The Peerless Modular Series has been introduced as a mounting system with just over a dozen components that combine to meet virtually any installation application.
- Peerless Modular Series Single Screen Mount mounting component - for flat panel - black
- Product Type
- Mounting component
- Mounting Components
- Mount
- 13 cm x 8.7 cm x 13 cm
- Adjustments
- Tilt
- Recommended Use
- Flat panel
- Recommended Display Size
- 10"-65"
- Max Load Weight
- 100 kg
- Black
- 13 cm
- 8.7 cm
- 13 cm
- Black
AV Furniture
- Mount
- Recommended Use
- Flat panel
- Cable Management
- Cable Management System (CMS)
- 10"-65"
- Adjustments
- Tilt
- Max Load Weight
- 100 kg
- Rotating
