Peerless-AV Modular Series Dual-Pole Free Standing Floor Plate
Quicklinx: BVHTWS00 Mfr#: MOD-FPP2
£139.59 ex VAT
£167.50 inc VAT
Peerless-AV's Modular Mount Series features a full range of products to fulfill multiple requirements with a limited number of components. The universality of the components allows you to configure your own perfect custom flat-panel display or projector mounting solution for any application. The Modular Mount Series was developed with the professional AV installer in mind with a 2" (50 mm) diameter support pole that can be easily cut to length on the job site making it ideal for projects as well as for upgrading existing installations. The MOD-FPP2 pedestal base allows you to simply bolt the structure to the floor, eliminating the need for walls or ceilings when placing your display.
  • Robust design
    The dual pole floor plate ensures a stable and secure mounting solution, ideal for high-traffic areas and public spaces. Its robust design supports flat panels ranging from 46" to 90", accommodating a wide variety of screen sizes for optimal viewing.
  • Versatile placement
    Designed for in-floor mounting, this component offers a sleek and unobtrusive installation option. It's perfect for creating a professional look in any environment, from corporate lobbies to educational institutions, without compromising on space or visibility.
Peerless Modular Series MOD-FPP2 mounting component - for flat panel - black powder coat
Mounting component - in-floor mounted
Mounting Components
Dual pole floor plate
30 cm x 20 cm x 30.8 cm
4.77 kg
Recommended Use
Flat panel
Recommended Display Size
46"-90"
Max Load Weight
192 kg
Black powder coat
5-year warranty
30 cm
20 cm
30.8 cm
4.77 kg
Black powder coat
AV Furniture
Mounting component
Mounting Components
Recommended Use
Flat panel
Placing / Mounting
In-floor mounted
46"-90"
Max Load Weight
192 kg
Limited warranty - 5 years
Brand: Peerless-AV
