Peerless-AV Modular Series Dual-Pole Cosmetic Cover For Modular Series
Quicklinx: CM8WWS00 Mfr#: MOD-ACF2
£62.69 ex VAT
£75.22 inc VAT
Peerless-AV's Modular mount series fulfills multiple requirements with a limited number of components. The universality of the components allows you to configure your own perfect custom flat-panel display or projector mounting solution for any application. The Modular mount series was developed with the professional AV installer in mind with a 2" (50 mm) diameter support pole that can be easily cut to length on the job site making it ideal for new projects as well as for upgrading existing installations.
  • Versatile placement options
    Designed for both ceiling and floor mounting, the Peerless Modular Series MOD-ACF2 offers flexible installation options to meet diverse needs. Whether it's a flat panel or projector, this mounting component ensures a secure and optimal placement.
  • Robust design
    With a maximum load weight of 192 kg, this mounting component is built to support large displays ranging from 46"-90". Its robust construction, complemented by security screws, provides a stable and secure setup for your valuable equipment.
  • Seamless integration
    The MOD-ACF2 features a sleek plate cover and two pole holes, allowing for a clean and unobtrusive installation. This design not only enhances the aesthetic appeal of your space but also ensures easy access for maintenance and adjustments.
Peerless Modular Series MOD-ACF2 mounting component - for flat panel / projector - black powder coat
Mounting component - ceiling mountable, in-floor mounted
Mounting Components
Plate cover
20.4 cm x 20.4 cm x 3.1 cm
450 g
Recommended Use
Flat panel / projector
Recommended Display Size
46"-90"
Max Load Weight
192 kg
Black powder coat
20.4 cm
20.4 cm
3.1 cm
450 g
Black powder coat
AV Furniture
Mounting component
Mounting Components
Plate cover
Recommended Use
Placing / Mounting
Ceiling mountable, in-floor mounted
46"-90"
Max Load Weight
192 kg
Security screws, 2 x pole holes
Limited warranty - 5 years
Brand: Peerless-AV
