Peerless-AV Modular Accessory Caps for Modular Poles - Kit of 2 Caps
Quicklinx: 9Z18WS00 Mfr#: MOD-ACAP
£4.44 ex VAT
£5.32 inc VAT
Modular Series Round plastic end caps insert into the pole ends to create a clean, sleek finish.
  • Durable design
    Crafted from high-quality plastic, the Tube End Cap Kit from Peerless Modular Series ensures longevity and durability, making it a reliable choice for securing pole-mounted AV furniture.
  • Easy installation
    Designed for simplicity, the mounting components allow for straightforward pole mount placement, facilitating a hassle-free setup process for your AV equipment.
Peerless Modular Series Tube End Cap Kit mounting component - black
Mounting component - pole mount
Packaged Quantity
2 (specifications are for single item)
Mounting Components
End caps
5 cm
Material
Plastic
Packaged Quantity
5 cm
Material
Plastic
AV Furniture
Mounting component
Mounting Components
End caps
Placing / Mounting
Pole mount
Brand: Peerless-AV
