Modular Series Round plastic end caps insert into the pole ends to create a clean, sleek finish.
Durable design
Crafted from high-quality plastic, the Tube End Cap Kit from Peerless Modular Series ensures longevity and durability, making it a reliable choice for securing pole-mounted AV furniture. -
Easy installation
Designed for simplicity, the mounting components allow for straightforward pole mount placement, facilitating a hassle-free setup process for your AV equipment.
- Peerless Modular Series Tube End Cap Kit mounting component - black
- Product Type
- Mounting component - pole mount
- Packaged Quantity
- 2 (specifications are for single item)
- Mounting Components
- End caps
- 5 cm
- Material
- Plastic
- Black
- Packaged Quantity
- 5 cm
- Material
- Plastic
- Black
AV Furniture
- End caps
- Placing / Mounting
- Pole mount
