Peerless-AV Metal Shelf
Quicklinx: BX1YWS00 Mfr#: ACC-MS
£74.86 ex VAT
£89.83 inc VAT
The SmartMount Metal Shelf is designed to attach to the newly redesigned SmartMount SR Flat Panel cart and SS Flat Panel stand. The shelf provides a secure yet sleek surface for various AV equipment and accessories to create great viewing experience.
  • Quick release functionality
    The Peerless-AV SmartMount ACC-MS features a quick release mechanism, allowing for easy installation and adjustment of your AV system. This functionality ensures that setup and updates to your system can be done swiftly and efficiently, minimizing downtime and hassle.
  • Durable construction
    Constructed from high-quality metal and designed to be scratch-resistant, the SmartMount ACC-MS ensures longevity and durability. Its robust build quality means it can withstand the rigors of daily use while maintaining its aesthetic appeal.
  • Optimized for AV systems
    Specifically designed for AV systems, this mounting component includes a shelf that supports a maximum load weight of 4.55 kg. It's the perfect solution for securely housing your audiovisual equipment, providing both functionality and style.
Peerless-AV SmartMount ACC-MS mounting component - for AV System - black powder coat
Mounting component
Mounting Components
Shelf
50.8 cm x 41.6 cm x 8.7 cm
5.91 kg
Recommended Use
AV System
Max Load Weight
4.55 kg
Material
Metal
Black powder coat
5-year warranty
50.8 cm
41.6 cm
8.7 cm
5.91 kg
Material
Metal
Black powder coat
AV Furniture
Mounting component
Mounting Components
Shelf
Recommended Use
AV System
Max Load Weight
4.55 kg
Quick release, scratch-resistant
Dimensions & Weight Details
RoHS
Limited warranty - 5 years
Brand: Peerless-AV
