Peerless-AV Medium/Large Articulating Wall Mount For 32-50" Screens
Quicklinx: BBLGWS00 Mfr#: TRA746
Type: Mounting kit
£52.71 ex VAT
£63.25 inc VAT
Delivering excellent strength and durability, this articulating wall mount supports flat panel TVs from 37" to 56". Its smooth motion, extensive reach, swivel capabilities and tilt adjustment deliver ideal TV placement for perfect viewing from anywhere in the room.
  • Effortless adjustment
    With both tilt and swivel adjustments, the Peerless Tru Vue TRA765 mounting kit allows for optimal viewing angles, ensuring a comfortable and customizable viewing experience.
  • Seamless installation
    The hook-and-loop strap feature simplifies the installation process, making it easy to securely attach your flat panel to the wall without the need for professional help.
Peerless Tru Vue TRA765 mounting kit - for flat panel - matte black
Mounting kit - wall-mountable
Mounting Components
Articulating wall mount
Adjustments
Tilt
Recommended Use
Flat panel
Recommended Display Size
32"-50"
VESA Mounting Interface
400 x 400 mm
Max Load Weight
32 kg
Matte black
5-year warranty
Matte black
AV Furniture
Mounting kit
Mounting Components
Recommended Use
Flat panel
Placing / Mounting
Wall-mountable
400 x 400 mm
32"-50"
Adjustments
Tilt
Max Load Weight
32 kg
Adjustable depth, swivel adjustment, Hook-and-Hang
Limited warranty - 5 years
Type: Mounting kit
Brand: Peerless-AV
