Delivering excellent strength and durability, this articulating wall mount supports flat panel TVs from 37" to 56". Its smooth motion, extensive reach, swivel capabilities and tilt adjustment deliver ideal TV placement for perfect viewing from anywhere in the room.
Effortless adjustment
With both tilt and swivel adjustments, the Peerless Tru Vue TRA765 mounting kit allows for optimal viewing angles, ensuring a comfortable and customizable viewing experience. -
Seamless installation
The hook-and-loop strap feature simplifies the installation process, making it easy to securely attach your flat panel to the wall without the need for professional help.
- Peerless Tru Vue TRA765 mounting kit - for flat panel - matte black
- Product Type
- Mounting kit - wall-mountable
- Mounting Components
- Articulating wall mount
- Adjustments
- Tilt
- Recommended Use
- Flat panel
- Recommended Display Size
- 32"-50"
- VESA Mounting Interface
- 400 x 400 mm
- Max Load Weight
- 32 kg
- Matte black
- 5-year warranty
- Matte black
AV Furniture
- Mounting kit
- Recommended Use
- Flat panel
- Placing / Mounting
- Wall-mountable
- 400 x 400 mm
- 32"-50"
- Adjustments
- Tilt
- Max Load Weight
- 32 kg
- Adjustable depth, swivel adjustment, Hook-and-Hang
- Limited warranty - 5 years
