Peerless offers the industry's widest range of accessories to complement your installation. From various ceiling plates and decouplers, to cord management adapters and surface specific hardware, Peerless can provide virtually anything you need to accessorize your installation and meet demanding application requirements.
                Durable constructionCrafted from high-quality plastic and steel, the Peerless ACC 310 mounting component ensures a sturdy and reliable base for your flat panel cart. Its robust design supports optimal performance and longevity.
                Versatile mountingThe Peerless ACC 310 comes equipped with feet mounting components, offering a secure and stable foundation for flat panel carts. This feature provides flexibility in setup and installation, catering to various user needs.
- Peerless ACC 310 mounting component - for flat panel cart - black
- Product Type
- Mounting component
- Packaged Quantity
- 4 (specifications are for single item)
- Mounting Components
- Feet
- 3.1 cm x 3.1 cm x 5.1 cm
- 0.4 kg
- Recommended Use
- Flat panel cart
- Material
- Plastic, steel
- Black
- Packaged Quantity
- 3.1 cm
- 3.1 cm
- 5.1 cm
- 0.4 kg
- Material
- Plastic, steel
- Black
AV Furniture
- Feet
- Recommended Use
- Flat panel cart
