Peerless-AV iPad Stand - Black
Quicklinx: 9Z3LWS00 Mfr#: PTS510I
£273.33 ex VAT
£327.99 inc VAT
The light weight and durable Kiosk Floor Stand for iPad tablets from Peerless-AV is the ideal signage solution for permanent or temporary exhibits. The convenient pull pin device on the back of the stand, quickly and easily allows the user to rotate the screen to match the orientation of the content. Internal cable management allows the cables to exit the rear of the stand or continue through the base for a clean appearance. Clearance holes in the base allow the user to secure the stand to the floor or leave free standing for quick repositioning.
  • Effortless placement
    Designed for floor-standing placement, this Peerless Kiosk Floor Stand offers a stable and secure positioning for tablets, enhancing user interaction in various settings.
  • Robust support
    With a maximum load weight of 2.3 kg, this stand is built to hold your device securely, ensuring peace of mind during use.
Peerless Kiosk Floor Stand PTS510I stand - for tablet - black powder coat
Stand - floor-standing
29.2 cm x 41.2 cm x 125.8 cm
Recommended Use
Tablet
Recommended Display Size
9.7"
Max Load Weight
2.3 kg
Black powder coat
29.2 cm
41.2 cm
125.8 cm
Black powder coat
AV Furniture
Stand
Recommended Use
Tablet
Placing / Mounting
Floor-standing
Cable Management
Integrated cable management
9.7"
Max Load Weight
2.3 kg
Portrait to landscape movement
Brand: Peerless-AV
