This ceiling fixture is designed for installation between two wood joists on 16" to 20" centers. The position of the threaded fitting, where the extension column attaches, is adjustable. The 1 1/2-11.5 NPS threaded fitting interfaces with Peerless Fixed Length and Adjustable Length Extension Columns. Wood screws for installation are included.
- Peerless ACC 120 - mounting component
- Product Type
- Mounting component - between seats, in-ceiling mounted
- Mounting Components
- Ceiling plate
- 3.8 kg
- Max Load Weight
- 136 kg
- Material
- Steel
- Black
- 3.8 kg
- Material
- Steel
- Black
AV Furniture
- Ceiling plate
- Placing / Mounting
- Between seats, in-ceiling mounted
- Max Load Weight
- 136 kg
