Peerless-AV Internal Joist Mount for 16'' or 20'' Centers
Quicklinx: 9Z1YWS00 Mfr#: ACC120
£86.66 ex VAT
£103.99 inc VAT
This ceiling fixture is designed for installation between two wood joists on 16" to 20" centers. The position of the threaded fitting, where the extension column attaches, is adjustable. The 1 1/2-11.5 NPS threaded fitting interfaces with Peerless Fixed Length and Adjustable Length Extension Columns. Wood screws for installation are included.
Peerless ACC 120 mounting component - black
Mounting component - between seats, in-ceiling mounted
Mounting Components
Ceiling plate
3.8 kg
Max Load Weight
136 kg
Material
Steel
3.8 kg
Material
Steel
AV Furniture
Mounting component
Mounting Components
Ceiling plate
Placing / Mounting
Between seats, in-ceiling mounted
Max Load Weight
136 kg
Brand: Peerless-AV
