Peerless-AV Full Service Video Wall Mount with Quick Release
Quicklinx: 9Z0QWS00 Mfr#: DS-VW795-QR
42 In Stock
£463.64 ex VAT
£556.36 inc VAT
The DS-VW795-QR full service video wall mount with quick release offers an easy to install and service solution for both landscape and portrait large format displays. Designed for quick service access in recessed video wall applications, the DS-VW795-QR provides versatility demanded by today's integrator. With the quick-release functionality, users have the ability to articulate the display from the wall by gently pressing on the front of the display. Featuring tool-less micro adjustment at eight points, the mounts can overcome uneven walls to create a seamless video wall display. In addition, custom wall plate spacers eliminating the guesswork and on-site installation calculations and measurement reducing installation time and cost. With no-tool-required micro-adjustments and easy-access to any display for quick serviceability it's the ultimate video wall mounting solution.
  • Effortless installation
    The Peerless-AV SmartMount Full Service Video Wall Mount with Quick Release is designed for an effortless installation process, featuring 8 knobs for micro-adjustment and adjustable depth, ensuring a perfect fit for your display.
  • Seamless cable management
    Integrated cable management keeps cables neatly organized, providing a clean and clutter-free look for your video wall setup.
  • Robust support
    With the ability to support flat panels ranging from 65" to 98" and a maximum load weight of 102 kg, this mounting kit is built for robust and reliable support.
Peerless-AV SmartMount Full Service Video Wall Mount with Quick Release DS-VW795-QR mounting kit - for flat panel - black powder coat
Mounting kit - wall-mountable
Mounting Components
Wall mount
83.1 cm 71.2 cm
Adjustable Depth
9.3-11.3 cm
18.1 kg
Recommended Use
Flat panel
Recommended Display Size
65"-98"
VESA Mounting Interface
200 x 200 mm, up to 600 x 600 mm
Max Mounting Pattern Size
600 x 600 mm
Max Load Weight
102 kg
Black powder coat
5-year warranty
83.1 cm
71.2 cm
Adjustable Depth
9.3-11.3 cm
18.1 kg
Black powder coat
AV Furniture
Mounting kit
Mounting Components
Wall mount
Recommended Use
Flat panel
Placing / Mounting
Wall-mountable
600 x 600 mm
Cable Management
65"-98"
Max Load Weight
102 kg
Adjustable depth, quick release, 8 knobs micro adjustment
Limited warranty - 5 years
Brand: Peerless-AV
