Peerless-AV Full Service Video Wall Mount with Quick Release - Landscape
Quicklinx: 9Z0KWS00 Mfr#: DS-VW765-LQR
29 In Stock
£277.51 ex VAT
£333.01 inc VAT
Video walls should be easy to configure, quick to install, and a snap to maintain. The DS-VW765-LQR full-service video wall mount with a quick release from Peerless-AV is designed for quick service access in recessed video wall applications. It provides versatility demanded by installers. With the quick-release functionality, users have the ability to articulate the display from the wall by gently pressing on the front of the display. The DS-VW765-LQR has a no-tool-required micro-adjustment feature and provides easy-access to any display, creating the ideal video wall. The custom wall plate spacers eliminate guesswork and on-site installation calculations and measurements, reducing installation time and cost. This innovative design, combined with a ready-to-install mount, makes this the fastest video wall installation. Loaded with time saving features, this full-service video mount is the ultimate video wall mounting solution.
  • Effortless adjustment
    With 8 knobs for micro-adjustment, the Peerless-AV SmartMount DS-VW765-LQR offers effortless precision in aligning video walls, ensuring a seamless display and optimal viewing experience.
  • Integrated cable management
    The design includes integrated cable management, keeping cables neatly organized and out of sight for a clean, professional appearance.
  • Versatile compatibility
    Accommodating display sizes from 46" to 65" and compatible with flat panel mount interfaces from 200 x 200 mm up to 700 x 400 mm, this mounting kit is versatile enough for various video wall configurations.
  • Robust construction
    Designed to support a maximum load weight of 56.8 kg, the DS-VW765-LQR ensures a secure and stable mount for valuable display equipment.
  • Quick setup
    Featuring a quick release mechanism and adjustable depth, the mounting kit allows for easy installation and maintenance, saving time and effort.
Peerless-AV SmartMount DS-VW765-LQR mounting kit - for video wall - black powder coat
Mounting kit - wall-mountable
Mounting Components
Wall mount
90.4 cm 54.3 cm
Adjustable Depth
7.8-47.2 cm
Adjustments
Tilt
15.9 kg
Recommended Use
Video wall
Recommended Display Size
46"-65"
VESA Mounting Interface
200 x 200 mm, up to 700 x 400 mm
Max Load Weight
56.8 kg
Black powder coat
5-year warranty
LG 47LV35A, 49VL5B, 49VM5C, 55LV35A, 55LV75A, 55LV77A, 55VH7B, 55VM5B
90.4 cm
54.3 cm
Adjustable Depth
7.8-47.2 cm
15.9 kg
Black powder coat
AV Furniture
Mounting kit
Mounting Components
Wall mount
Recommended Use
Video wall
Placing / Mounting
Wall-mountable
Cable Management
46"-65"
Adjustments
Tilt
Max Load Weight
56.8 kg
Adjustable depth, quick release, 8 knobs micro adjustment
Limited warranty - 5 years
Brand: Peerless-AV
