Peerless-AV Full-Service Video Wall Mount for 40-65" Displays
Quicklinx: 9S6NWS00 Mfr#: DS-VW765-LAND
30 In Stock
£343.41 ex VAT
£412.09 inc VAT
Video walls should be easy to configure, quick to install, and a snap to maintain. No, it's not a dream, it's the DS-VW765-LAND Full-Service Video Wall Mount from Peerless-AV. Create any configuration imaginable, but leave the tedious calculations to the custom wall plate spacers. Just install the first mount. Then use the custom wall plate spacers to perfectly place each additional mount on the wall. No measuring, no guessing, no mistakes. It couldn't be simpler. The excellent design combined with a mount that is ready-to-install right out of the box makes this fast installing video wall system ever. Now in a design that is 20% lighter and loaded with time saving features like no-tool-required micro-adjustments and easy-access to any display for quick serviceability it's the ultimate video wall mounting solution.
  • No tedious calculations and no guesswork
    Custom wall plate spacers eliminate the guesswork and on-site installation calculations.
  • Easy pull-out service access
    Easy-to-use pull-out/prop-open mechanism provides quick service access; spring-loaded mechanism securely clicks the display back into place.
  • Open wall plate architecture
    Allows for total wall access that increases electrical and cable management options.
  • No tools required for micro-adjustment
    Simple, tool-less microadjustments at 8 points seamlessly align the displays.
  • Clean look
    Integrated cable management tie-backs make display-to-display cabling easier.
Peerless-AV SmartMount Full-Service Video Wall Mount DS-VW765-LAND mounting kit - for flat panel - black
Mounting kit - wall-mountable
Mounting Components
Wall mount
89 cm x 78 cm x 50.8 cm
18 kg
Recommended Use
Flat panel
Recommended Display Size
40"-65"
VESA Mounting Interface
200 x 200 mm, 700 x 400 mm
Max Load Weight
56.8 kg
5-year warranty
89 cm
78 cm
50.8 cm
18 kg
AV Furniture
Mounting kit
Mounting Components
Wall mount
Recommended Use
Flat panel
Placing / Mounting
Wall-mountable
Cable Management
Cable Management System (CMS)
40"-65"
Max Load Weight
56.8 kg
Scratch-resistant, prop-open mechanism
Limited warranty - 5 years
Brand: Peerless-AV
