The DS-VW665 is the latest addition to the increasing lineup of modular video wall mounts from Peerless-AV. This mount includes innovative features that simplify the installation process, such and custom wall spacers and 8 points of tool-less micro adjustment. These unique features provide seamless display alignment of small or large video wall configurations while ensuring each mount is positioned for the specific display being used. In addition, integrated cable management tie-backs and a clean profile cap off the aesthetically pleasing install.
Effortless installation
The Peerless DS-VW665 mounting kit features adjustable depth and integrated cable management, making the installation process smooth and ensuring a clean, organized appearance without visible cables. -
Enhanced security
Equipped with security screws, the Peerless DS-VW665 offers an added layer of protection, ensuring your flat panel remains safe and securely mounted at all times. -
Versatile compatibility
Designed to support a wide range of display sizes from 40" to 65" and compatible with flat panel mount interfaces of 200 x 200 mm to 700 x 400 mm, this mounting kit is perfect for various flat panel models. -
Robust design
With the ability to hold up to 57 kg, the Peerless DS-VW665 mounting kit is built to support your flat panel securely, providing peace of mind and a stable viewing experience.
- Peerless DS-VW665 mounting kit - for flat panel - black powder coat
- Product Type
- Mounting kit - wall-mountable
- Mounting Components
- Wall mount
- 88.9 cm 50.8 cm
- Adjustable Depth
- 7.9 -9.8 cm
- 12 kg
- Recommended Use
- Flat panel
- Recommended Display Size
- 40"-65"
- VESA Mounting Interface
- 200 x 200 mm, 700 x 400 mm
- Max Load Weight
- 57 kg
- Black powder coat
- 88.9 cm
- 50.8 cm
- Adjustable Depth
- 7.9 -9.8 cm
- 12 kg
- Black powder coat
AV Furniture
- Mounting kit
- Wall mount
- Recommended Use
- Flat panel
- Placing / Mounting
- Wall-mountable
- Cable Management
- Integrated cable management
- 40"-65"
- Max Load Weight
- 57 kg
- Adjustable depth, security screws
