The DS-VW665 is the latest addition to the increasing lineup of modular video wall mounts from Peerless-AV. This mount includes innovative features that simplify the installation process, such and custom wall spacers and 8 points of tool-less micro adjustment. These unique features provide seamless display alignment of small or large video wall configurations while ensuring each mount is positioned for the specific display being used. In addition, integrated cable management tie-backs and a clean profile cap off the aesthetically pleasing install.
- Peerless DS-VW665 mounting kit - for flat panel - black powder coat
- Product Type
- Mounting kit - wall-mountable
- Mounting Components
- Wall mount
- 88.9 cm 50.8 cm
- Adjustable Depth
- 7.9 -9.8 cm
- 12 kg
- Recommended Use
- Flat panel
- Recommended Display Size
- 40"-65"
- VESA Mounting Interface
- 200 x 200 mm, 700 x 400 mm
- Max Load Weight
- 57 kg
- Black powder coat
- 88.9 cm
- 50.8 cm
- Adjustable Depth
- 7.9 -9.8 cm
- 12 kg
- Black powder coat
AV Furniture
- Mounting kit
- Wall mount
- Recommended Use
- Flat panel
- Placing / Mounting
- Wall-mountable
- Cable Management
- Integrated cable management
- 40"-65"
- Max Load Weight
- 57 kg
- Adjustable depth, security screws
