Peerless-AV Flat Video Wall Mount for 40-65" Displays
Quicklinx: 9Z0JWS00 Mfr#: DS-VW665
£383.58 ex VAT
£460.29 inc VAT
The DS-VW665 is the latest addition to the increasing lineup of modular video wall mounts from Peerless-AV. This mount includes innovative features that simplify the installation process, such and custom wall spacers and 8 points of tool-less micro adjustment. These unique features provide seamless display alignment of small or large video wall configurations while ensuring each mount is positioned for the specific display being used. In addition, integrated cable management tie-backs and a clean profile cap off the aesthetically pleasing install.
  • Effortless installation
    The Peerless DS-VW665 mounting kit features adjustable depth and integrated cable management, making the installation process smooth and ensuring a clean, organized appearance without visible cables.
  • Enhanced security
    Equipped with security screws, the Peerless DS-VW665 offers an added layer of protection, ensuring your flat panel remains safe and securely mounted at all times.
  • Versatile compatibility
    Designed to support a wide range of display sizes from 40" to 65" and compatible with flat panel mount interfaces of 200 x 200 mm to 700 x 400 mm, this mounting kit is perfect for various flat panel models.
  • Robust design
    With the ability to hold up to 57 kg, the Peerless DS-VW665 mounting kit is built to support your flat panel securely, providing peace of mind and a stable viewing experience.
Peerless DS-VW665 mounting kit - for flat panel - black powder coat
Mounting kit - wall-mountable
Mounting Components
Wall mount
88.9 cm 50.8 cm
Adjustable Depth
7.9 -9.8 cm
12 kg
Recommended Use
Flat panel
Recommended Display Size
40"-65"
VESA Mounting Interface
200 x 200 mm, 700 x 400 mm
Max Load Weight
57 kg
Black powder coat
88.9 cm
50.8 cm
Adjustable Depth
7.9 -9.8 cm
12 kg
Black powder coat
AV Furniture
Mounting kit
Mounting Components
Wall mount
Recommended Use
Flat panel
Placing / Mounting
Wall-mountable
Cable Management
Integrated cable management
40"-65"
Max Load Weight
57 kg
Adjustable depth, security screws
Brand: Peerless-AV
