The SR555E SmartMount video conferencing cart offers an array of features perfect for any setting where telecommunication is required. The mobility of the cart eliminates the need for multiple video conferencing systems, lowering your overall system cost. The structure is optimized to hold two 40"-55" displays, providing clear visibility for all participants. The camera locates anywhere above either display, for near perfect eye contact during your meetings. A lockable storage area houses all components inside the enclosure and the upper door doubles as a laptop workstation when needed.
 - Peerless-AV SmartMount SR555E cart - for 2 flat panels / video conferencing system - textured black powder
- Product Type
 - Cart - lockable
 - 178.4 cm x 73.7 cm x 198.3 cm
- Adjustments
 - Yaw
 - 81.8 kg
- Recommended Use
 - 2 flat panels / video conferencing system
- Recommended Display Size
 - 40"-55"
- VESA Mounting Interface
 - 200 x 200 mm, 400 x 400 mm
- Max Load Weight
 - 86.2 kg
 - Textured black powder
- Wheels Qty
 - 4
 - 5-year warranty
 - 178.4 cm
 - 73.7 cm
 - 198.3 cm
 - 81.8 kg
AV Furniture
 - Cart
- Recommended Use
- Cable Management
 - Integrated cable management
- Lockable
 - 40"-55"
- Adjustments
 - Yaw
- Max Load Weight
 - 86.2 kg
- Wheels Qty
 - 4
- Wheel Diameter
 - 10.2 cm
- Brakes Qty
 - 2
 - Limited warranty - 5 years
