The SR575E Video Conference Cart offers an array of features perfect for any setting where telecommunication is required. The mobility of the cart eliminates the need for multiple video conference systems, lowering your overall system cost. The structure is optimized to hold one 32"-75" display, providing clear visibility for all participants. The camera can be located directly above the display, for near perfect eye contact during your meetings. A lockable storage area houses all components inside the enclosure and the upper door doubles as a laptop with a display sized workstation when needed.
Effortless mobility
Equipped with four high-quality wheels, including two with brakes, the Peerless-AV SR575E cart ensures smooth, effortless mobility and stable positioning for your AV setup, making it ideal for dynamic environments. -
Seamless cable management
The integrated cable management system keeps cables organized and out of sight, providing a clean, professional appearance that enhances any room's aesthetics. -
Robust support
Designed to support LCD displays and video conferencing systems ranging from 32" to 75", this cart can handle a maximum load of 68.2 kg, ensuring your equipment is secure and stable. -
Safety and compliance
With rubber corner protectors and adherence to RoHS, UL, and cUL standards, the SR575E cart offers added safety for your equipment and peace of mind for users.
 - Peerless-AV SR575E cart - for LCD display / video conferencing system - brushed stainless steel, black texture powder coat
- Product Type
 - Cart
 - 88.9 cm x 73.7 cm x 198.3 cm
 - 74.1 kg
- Recommended Use
 - LCD display / video conferencing system
- Recommended Display Size
 - 32"-75"
- Outlets Qty
 - 6
- Max Load Weight
 - 68.2 kg
 - Brushed stainless steel, black texture powder coat
- Wheels Qty
 - 4
 - 88.9 cm
 - 73.7 cm
 - 198.3 cm
 - 74.1 kg
AV Furniture
 - Cart
- Recommended Use
- Cable Management
 - Integrated cable management
 - 32"-75"
- Max Load Weight
 - 68.2 kg
- Wheels Qty
 - 4
- Wheel Diameter
 - 10.2 cm
- Brakes Qty
 - 2
 - Rubber corner protectors
- Outlets Qty
 - 6
Dimensions & Weight Details
 - UL, cUL, RoHS
