Peerless-AV Flat Panel Stand for 32-65" Flat Panel Displays
Quicklinx: 9Z3WWS00 Mfr#: SS560F
£488.21 ex VAT
£585.85 inc VAT
The Flat Panel Stand is designed to provide ideal display viewing position, centralize audio video components and match the decorate of any environment. The full line of accessories enables each stand to be fully tailored to meet specific requirements; whether video conferencing from a boardroom or presenting on a trade show floor. And the internal cable management hides all the AV cabling, providing a clean, clutter-free look.
  • Versatile placement
    Designed for floor-standing placement, this stand offers flexibility in setup and is ideal for various room configurations.
  • Robust construction
    Crafted from aluminum, cold-rolled steel, and fused epoxy, the stand combines durability with a sleek, professional appearance.
  • Integrated cable management
    Keeps cables neatly organized and out of sight, enhancing the overall aesthetic and safety of your setup.
  • Secure display solution
    Features anti-theft protection and adjustable height, ensuring your flat panel is both secure and positioned at the optimal viewing angle.
  • Wide compatibility
    Supports a broad range of display sizes from 32"-75" and includes a VESA adapter for easy mounting of compatible flat panels.
Peerless Flat Panel Stand SS560F stand - for flat panel - black
Stand - floor-standing
Mounting Components
Base plate, column, VESA adapter
85.1 cm x 67.3 cm x 173.6 cm
Adjustments
Tilt
36 kg
Recommended Use
Flat panel
Recommended Display Size
32"-75"
VESA Mounting Interface
200 x 200 mm, 600 x 400 mm
Max Load Weight
68 kg
Material
Aluminium, cold-rolled steel, fused epoxy
18-year warranty
85.1 cm
67.3 cm
173.6 cm
36 kg
Material
AV Furniture
Stand
Mounting Components
Recommended Use
Flat panel
Placing / Mounting
Floor-standing
Cable Management
32"-75"
Adjustments
Tilt
Max Load Weight
68 kg
Adjustable height, anti-theft
Limited warranty - 18 years
Brand: Peerless-AV
