The Flat Panel Stand is designed to provide ideal display viewing position, centralize audio video components and match the decorate of any environment. The full line of accessories enables each stand to be fully tailored to meet specific requirements; whether video conferencing from a boardroom or presenting on a trade show floor. And the internal cable management hides all the AV cabling, providing a clean, clutter-free look.
Versatile placement
Designed for floor-standing placement, this stand offers flexibility in setup and is ideal for various room configurations. -
Robust construction
Crafted from aluminum, cold-rolled steel, and fused epoxy, the stand combines durability with a sleek, professional appearance. -
Integrated cable management
Keeps cables neatly organized and out of sight, enhancing the overall aesthetic and safety of your setup. -
Secure display solution
Features anti-theft protection and adjustable height, ensuring your flat panel is both secure and positioned at the optimal viewing angle. -
Wide compatibility
Supports a broad range of display sizes from 32"-75" and includes a VESA adapter for easy mounting of compatible flat panels.
- Peerless Flat Panel Stand SS560F stand - for flat panel - black
- Product Type
- Stand - floor-standing
- Mounting Components
- Base plate, column, VESA adapter
- 85.1 cm x 67.3 cm x 173.6 cm
- Adjustments
- Tilt
- 36 kg
- Recommended Use
- Flat panel
- Recommended Display Size
- 32"-75"
- VESA Mounting Interface
- 200 x 200 mm, 600 x 400 mm
- Max Load Weight
- 68 kg
- Material
- Aluminium, cold-rolled steel, fused epoxy
- Black
- 18-year warranty
- 85.1 cm
- 67.3 cm
- 173.6 cm
- 36 kg
- Material
- Black
AV Furniture
- Stand
- Recommended Use
- Flat panel
- Placing / Mounting
- Floor-standing
- Cable Management
- Integrated cable management
- 32"-75"
- Adjustments
- Tilt
- Max Load Weight
- 68 kg
- Adjustable height, anti-theft
- Limited warranty - 18 years
