Peerless-AV Flat Panel Single Screen Kit  1m - Black
Quicklinx: 8TK9WS00 Mfr#: MOD-FPSKIT100
Type: Mounting kit
£210.36 ex VAT
£252.43 inc VAT
Pre-assembled Modular Series Ceiling Kit including the following: 1 x MOD-CPC cathedral ceiling plate, 1 x MOD-P150 1.5m extension pole, 1 x MOD-FPMS single screen flat panel mount, 1 x MOD-UNL large universal adaptor.
  • Effortless adjustability
    Designed with a tilt feature, this mounting kit allows for easy angle adjustments, ensuring the perfect viewing experience from any position.
  • Versatile placement
    Ceiling-mountable design offers a unique solution for optimizing space and enhancing room aesthetics, making it ideal for both home and office settings.
  • Robust support
    Capable of supporting flat panels up to 60 kg, this mount kit combines reliability and strength, providing peace of mind for securing valuable displays.
Peerless Modular Series Flat Panel Ceiling Mount Kit mounting kit - for flat panel - powder coat
Mounting kit - ceiling mountable
Mounting Components
Ceiling mount
1 m
Adjustments
Tilt
Recommended Use
Flat panel
Recommended Display Size
32"-60"
VESA Mounting Interface
700 x 400 mm
Max Load Weight
60 kg
Powder coat
1 m
Powder coat
AV Furniture
Mounting kit
Mounting Components
Ceiling mount
Recommended Use
Flat panel
Placing / Mounting
Ceiling mountable
700 x 400 mm
Cable Management
Integrated cable management
32"-60"
Adjustments
Tilt
Max Load Weight
60 kg
Type: Mounting kit
Brand: Peerless-AV
