Peerless-AV Flat Panel Mount  Dual Pole for Modular Series Flat
Quicklinx: BVHVWS00 Mfr#: MOD-FPMS2
£83.44 ex VAT
£100.12 inc VAT
With the universality of the components, configure your own perfect custom flat-panel display or projector mounting solution for any application. The modular mount line was developed with the professional AV installer in mind. Designed around a 2" (50 mm) diameter pole, the line is ideal for projects as well as for upgrading existing installations. The MOD-FPMS2 tilt box is the perfect solution for mounting displays installed using the modular series line of mounts.
  • Versatile adjustments
    With its tilt feature, the Dual-Pole Single Display Mount from Peerless Modular Series offers optimal viewing angles, enhancing the user experience by allowing adjustments to reduce glare and improve visibility.
  • Robust support
    Designed to accommodate LCD displays ranging from 46" to 90", this mounting component supports a maximum load weight of 96 kg, ensuring a secure and stable setup for large screens.
  • Universal compatibility
    Featuring a VESA adapter and a pole mount, this mount is compatible with a wide range of display sizes and adheres to the standard flat panel mount interface of 200 x 200 mm, making it a versatile choice for various LCD displays.
Peerless Modular Series Dual-Pole Single Display Mount mounting component - for LCD display - black powder coat
Mounting component
Mounting Components
Pole mount, VESA adapter
26.3 cm x 10.2 cm x 24.3 cm
Adjustments
Tilt
5.68 kg
Recommended Use
LCD display
Recommended Display Size
46"-90"
VESA Mounting Interface
200 x 200 mm
Max Load Weight
96 kg
Black powder coat
5-year warranty
26.3 cm
10.2 cm
24.3 cm
5.68 kg
Black powder coat
AV Furniture
Mounting component
Mounting Components
Recommended Use
LCD display
200 x 200 mm
46"-90"
Adjustments
Tilt
Max Load Weight
96 kg
Limited warranty - 5 years
BVHV Peerless-AV Clamps Around Extension Pole To Stack Multiple Screens In Stock £32.33
Brand: Peerless-AV
