Peerless-AV Flat Panel Motorised Trolley
Quicklinx: GR5QWS00 Mfr#: PR598-M
More than 50 In Stock
£811.54 ex VAT
£973.84 inc VAT
The PR598-M motorised trolley provides a sleek and stylish solution for 50" to 98" displays featuring mobility appealing aesthetics and height adjustment at the touch of a button. A pre-assembled base ensures quick assembly while providing a rigid but attractive structure that fits into any décor. The ability to program pre-set heights via the digital display make this an easy convenient and adaptable solution ideal for boardrooms training rooms classrooms auditoriums exhibit halls and more.
Peerless-AV Paramount PR598-M cart - motorised - for media player / LCD display - black
Cart (motorised)
124.69 cm x 85.26 cm x 180.1 cm
Adjustable Height
100-150 cm
Lift
50 cm
Adjustments
52 kg
Recommended Use
Media player / LCD display
Recommended Display Size
50"-98"
VESA Mounting Interface
From 100 x 100 mm, up to 800 x 600 mm
Material
Metal
Wheels Qty
4
Package Content
Mounting hardware
5-year warranty
124.69 cm
85.26 cm
180.1 cm
Adjustable Height
100-150 cm
52 kg
Material
Metal
Package Content
Mounting hardware
AV Furniture
Cart
Design
Motorised
Recommended Use
50"-98"
Lift
50 cm
Adjustments
Wheels Qty
4
Wheel Diameter
7.62 cm
Brakes Qty
4
Assembly Required
Partial
Finish
Textured powder coat
Dimensions & Weight Details
Dimensions
Media shelf - width: 42 cm, depth: 37.5 cm , Cart base - width: 124.69 cm, depth: 85.26 cm
130 cm x 92 cm x 31 cm / 54 kg
Limited warranty - 5 years
Brand: Peerless-AV
Price Range Ex VAT: £750 - £1000
