The PR598-M motorised trolley provides a sleek and stylish solution for 50" to 98" displays featuring mobility appealing aesthetics and height adjustment at the touch of a button. A pre-assembled base ensures quick assembly while providing a rigid but attractive structure that fits into any décor. The ability to program pre-set heights via the digital display make this an easy convenient and adaptable solution ideal for boardrooms training rooms classrooms auditoriums exhibit halls and more.
- Peerless-AV Paramount PR598-M cart - motorised - for media player / LCD display - black
- Product Type
- Cart (motorised)
- 124.69 cm x 85.26 cm x 180.1 cm
- Adjustable Height
- 100-150 cm
- Lift
- 50 cm
- Adjustments
- 52 kg
- Recommended Use
- Media player / LCD display
- Recommended Display Size
- 50"-98"
- VESA Mounting Interface
- From 100 x 100 mm, up to 800 x 600 mm
- Material
- Metal
- Black
- Wheels Qty
- 4
- Package Content
- Mounting hardware
- 5-year warranty
- 124.69 cm
- 85.26 cm
- 180.1 cm
- Adjustable Height
- 100-150 cm
- 52 kg
- Material
- Metal
- Black
- Package Content
- Mounting hardware
AV Furniture
- Cart
- Design
- Motorised
- Recommended Use
- 50"-98"
- Lift
- 50 cm
- Adjustments
- Wheels Qty
- 4
- Wheel Diameter
- 7.62 cm
- Brakes Qty
- 4
- Assembly Required
- Partial
- Finish
- Textured powder coat
Dimensions & Weight Details
- Dimensions
- Media shelf - width: 42 cm, depth: 37.5 cm , Cart base - width: 124.69 cm, depth: 85.26 cm
- Shipping Dimensions (WxDxH) / Weight
- 130 cm x 92 cm x 31 cm / 54 kg
- Limited warranty - 5 years
