Fixed length extension EXT model columns are constructed of 11/2" 11.5 NPT schedule 40 pipe threaded and notched on both ends for safety locking.
- Peerless EXT 103 mounting component - black
- Product Type
- Mounting component
- Mounting Components
- Extension column
- 4.8 cm x 4.8 cm x 1 m
- 3.6 kg
- Black
- 4.8 cm
- 4.8 cm
- 1 m
- 3.6 kg
- Black
AV Furniture
- Extension column
