Increase productivity by freeing up desk space with more efficient display positioning. The 620AD series is a dual display Full-Motion Plus Wall Mount, and includes a grommet and desktop clamp mount solution. Installation is quick and easy, and secures a display with a quick release mechanism. Instantly set the height of the displays by raising or lowering 12.6", extending up to 22", and tilting forward and back. Furthermore, the LCT620AD can pan and rotate for a comfortable portrait or landscape viewing.
Effortless adjustment
With its adjustable height, tilt and swivel design, and the ability to switch from portrait to landscape movement, the Peerless 620AD Series Desktop Mount offers flexibility. This ensures an optimal viewing experience, whether for work or entertainment. -
Seamless integration
The integrated cable management system keeps your workspace neat and organized by hiding wires and cables. This feature, combined with the sleek design of the mount, enhances the overall aesthetic of your desktop setup. -
Versatile compatibility
Designed to support two LCD displays ranging from 12"-30" (30.5-76.2 cm), and compatible with flat panel mount interfaces of 100 x 100 mm and 75 x 75 mm, this mounting kit is a versatile solution for a wide range of display needs. -
Easy installation
Featuring a quick release mechanism, desk clamp mount, grommet mount, and dual articulating arm, the LCT620AD model ensures a hassle-free setup. This allows for a swift and secure installation on any desktop or table mount situation.
- Peerless 620AD Series Desktop Mount LCT620AD mounting kit - Tilt & Swivel - for 2 LCD displays - black
- Product Type
- Mounting kit (Tilt & Swivel) - desktop
- Recommended Use
- 2 LCD displays
- Recommended Display Size
- 12"-30"
- VESA Mounting Interface
- 100 x 100 mm, 75 x 75 mm
- Black
- Black
AV Furniture
- Mounting kit
- Design
- Tilt & Swivel
- Recommended Use
- 2 LCD displays
- Placing / Mounting
- Desktop
- Cable Management
- Integrated cable management
- 12"-30"
- Adjustable height, quick release, portrait to landscape movement
