Peerless-AV Desktop Swivel Mount (Top Bolt-Down) 200x100 & 200x200
Quicklinx: 9Z3FWS00 Mfr#: HP432-002
The HP432-002 flat panel desktop swivel mount is designed as a functional and secure solution for desktop-mounted displays in hospitality applications. The mount directly bolts-down to the desktop surface for safety and security, with security screws that attach the display to the mount adaptor plate. With up to 30 degrees of swivel each direction, this mount provides a low-cost solution to fit a variety of needs and room configurations.
Peerless Desktop Swivel Mount HP432-002 mounting kit - for flat panel - black powder coat
Mounting kit
Mounting Components
Swivel pipe, adapter plate, floor plate
22.2 cm x 10.2 cm
Adjustable Height
42.6-57.2 cm
2.72 kg
Recommended Use
Flat panel
Recommended Display Size
26"-37"
VESA Mounting Interface
100 x 100 mm, 200 x 200 mm, 200 x 100 mm, 100 x 200 mm
Max Load Weight
36 kg
Material
Fused epoxy
Black powder coat
22.2 cm
10.2 cm
Adjustable Height
42.6-57.2 cm
2.72 kg
Material
Fused epoxy
Black powder coat
AV Furniture
Mounting kit
Mounting Components
Recommended Use
Flat panel
26"-37"
Max Load Weight
36 kg
Adjustable height, swivel base, scratch-resistant, security screws
