The HP450 universal flat panel desktop swivel mount is designed to provide security and functionality for installations in the lodging industry. A universal adapter plate is integrated to the mount to fit many 32" to 50" screens. Utilizing Peerless's security hardware, a decorative base, internal cord management, and multiple swivel options, this mount offers a clean look to a stress-free application.
Adjustable comfort
The Peerless Universal Desktop Swivel Mount offers an adjustable height feature, ensuring optimal viewing angles and comfort for users. This flexibility allows for a personalized setup, catering to the ergonomic needs of any individual. -
Durable design
Constructed from fused epoxy and hardened steel, this mounting kit is designed to withstand the test of time. Its scratch-resistant surface and security screws add an extra layer of durability and peace of mind, knowing your flat panel is securely mounted. -
Versatile placement
Designed for desktop and table-top placement, the Peerless Universal Desktop Swivel Mount is ideal for a variety of settings. Whether it's for home, office, or educational purposes, this mount accommodates flat panels ranging from 32" to 50", providing a stable and reliable solution.
 - Peerless Universal Desktop Swivel Mount HP450 mounting kit - Swivel Design - for flat panel - black
- Product Type
 - Mounting kit (Swivel Design) - desktop
- Mounting Components
 - Support pipe, adapter plate, base backer plate, desktop swivel base
 - 10.9 kg
- Recommended Use
 - Flat panel
- Recommended Display Size
 - 32"-50"
- Max Load Weight
 - 68 kg
- Material
 - Hardened steel, fused epoxy
 - Black
 - 10.9 kg
- Material
 - Black
AV Furniture
 - Mounting kit
- Design
 - Swivel Design
- Recommended Use
 - Flat panel
- Placing / Mounting
 - Desktop
 - 32"-50"
- Max Load Weight
 - 68 kg
 - Adjustable height, scratch-resistant, security screws
