Peerless-AV Dedicated Flat Panel Adaptor Plate for VESA 400x400 Pattern
Quicklinx: 9YZSWS00 Mfr#: PLP-V4X4
£88.70 ex VAT
£106.44 inc VAT
Large Flat Panel adapter plates (PLP models) are either universally compatible with most large flat panels, or uniquely compatible with one screen make or model. Peerless adapter plates for flat panels allow users to choose between Peerless' wide array of applications and accessories to mount a flat panel virtually anywhere.
Peerless PLP V4X4 mounting component - for flat panel - black
Mounting component
Mounting Components
Mounting adapter
Recommended Use
Flat panel
VESA Mounting Interface
400 x 400 mm
Material
Cold-rolled steel
Insignia NS-PDP32-09; NuVision NVU47DCM; Philips 42PFL3403D, 47PFL7403D; Magnavox 42MF438B, 52MF438B; Samsung LN55B650; Sharp LC-46D64U, 52D65U, 52D65UBN
Material
Cold-rolled steel
AV Furniture
Mounting component
Mounting Components
Mounting adapter
Recommended Use
Flat panel
400 x 400 mm
Scratch-resistant
Insignia NS-PDP32-09 , NuVision NVU47DCM , Philips 42PFL3403D, 47PFL7403D , Philips Magnavox 42MF438B, 52MF438B , Samsung LN55B650 , Sharp LC-46D64U, 52D65U, 52D65UBN
Brand: Peerless-AV
