Large flat panel adapter plates (PLP models) are either universally compatible with most large flat panels, or uniquely compatible with one screen make or model. Peerless adapter plates for flat panels allow users to choose between Peerless' wide array of applications and accessories to mount a flat panel virtually anywhere.
 - Peerless PLP V3X3 mounting component - for flat panel - black
- Product Type
 - Mounting component
- Mounting Components
 - Mounting adapter
 - 33 cm x 1.5 cm x 32 cm
 - 1.7 kg
- Recommended Use
 - Flat panel
- VESA Mounting Interface
 - 300 x 300 mm
- Material
 - Cold-rolled steel, fused epoxy
 - Black
- Designed For
 - Sharp LC-32, 32D64, 37D64; Sony KDL-37, 37L4000, 37M4000, 37N4000, 40, 40S4100, 40V4100, 40V4150, 40W4100, 40Z4100, 42V4100, 46, 46D3500, 46S4100, 46V4100, 46W4100, 46W4150, 46Z4100, 52, 52S5100, 52V4000, 52V4100, 52V5500, 52W4100, 52W5100, 52W5500
 - 33 cm
 - 1.5 cm
 - 32 cm
 - 1.7 kg
- Material
 - Black
AV Furniture
 - Mounting adapter
- Recommended Use
 - Flat panel
 - 300 x 300 mm
 - Scratch-resistant, anti-theft
- Designed For
 - Sharp LC-32D64U, 32GP2U, 32GP3U-B, 32GP3U-R, 32GP3U-W, 37D64U , Sony KDL-37L4000, KDL-37M4000, KDL-37N4000, KDL-37XBR6, KDL-40S4100, KDL-40V4100, KDL-40V4150, KDL-40W4100, KDL-40XBR6, KDL-40XBR7, KDL-40Z4100, KDL-42V4100, KDL-46D3500, KDL-46S4100, KDL-46V4100, KDL-46W4100, KDL-46W4150, KDL-46XBR6, KDL-46XBR8, KDL-46Z4100, KDL-52S5100, KDL-52V4000, KDL-52V4100, KDL-52V5500, KDL-52W4100, KDL-52W5100, KDL-52W5500, KDL-52XBR6
