Peerless-AV Dedicated Flat Panel Adaptor Plate for VESA 300x300 Pattern
Quicklinx: 9YZRWS00 Mfr#: PLP-V3X3
£70.96 ex VAT
£85.15 inc VAT
Large flat panel adapter plates (PLP models) are either universally compatible with most large flat panels, or uniquely compatible with one screen make or model. Peerless adapter plates for flat panels allow users to choose between Peerless' wide array of applications and accessories to mount a flat panel virtually anywhere.
Peerless PLP V3X3 mounting component - for flat panel - black
Mounting component
Mounting Components
Mounting adapter
33 cm x 1.5 cm x 32 cm
1.7 kg
Recommended Use
Flat panel
VESA Mounting Interface
300 x 300 mm
Material
Cold-rolled steel, fused epoxy
Sharp LC-32, 32D64, 37D64; Sony KDL-37, 37L4000, 37M4000, 37N4000, 40, 40S4100, 40V4100, 40V4150, 40W4100, 40Z4100, 42V4100, 46, 46D3500, 46S4100, 46V4100, 46W4100, 46W4150, 46Z4100, 52, 52S5100, 52V4000, 52V4100, 52V5500, 52W4100, 52W5100, 52W5500
33 cm
1.5 cm
32 cm
1.7 kg
Material
AV Furniture
Mounting component
Mounting Components
Mounting adapter
Recommended Use
Flat panel
300 x 300 mm
Scratch-resistant, anti-theft
Sharp LC-32D64U, 32GP2U, 32GP3U-B, 32GP3U-R, 32GP3U-W, 37D64U , Sony KDL-37L4000, KDL-37M4000, KDL-37N4000, KDL-37XBR6, KDL-40S4100, KDL-40V4100, KDL-40V4150, KDL-40W4100, KDL-40XBR6, KDL-40XBR7, KDL-40Z4100, KDL-42V4100, KDL-46D3500, KDL-46S4100, KDL-46V4100, KDL-46W4100, KDL-46W4150, KDL-46XBR6, KDL-46XBR8, KDL-46Z4100, KDL-52S5100, KDL-52V4000, KDL-52V4100, KDL-52V5500, KDL-52W4100, KDL-52W5100, KDL-52W5500, KDL-52XBR6
Brand: Peerless-AV
