- Peerless CM60 mounting component - for flat panel - black
- Product Type
- Mounting component - wall-mountable
- Mounting Components
- Adapter plate
- 15 kg
- Recommended Use
- Flat panel
- Recommended Display Size
- 40"-60"
- Max Load Weight
- 90.8 kg
- Material
- Cold-rolled steel, fused epoxy
- Black
- Designed For
- OneMount Flat Panel Modular Wall Mount ONE-TP; PARAMOUNT Universal Flat Wall Mount PF640, PF650, PF660; PARAMOUNT Universal Tilt Wall Mount PT640, PT650, PT660; SmartMount Universal Flat Wall Mount SF640, SF650, SF660; SmartMount Universal Tilt Wall Mount ST640, ST650, ST660
- 15 kg
- Material
- Black
AV Furniture
- Adapter plate
- Recommended Use
- Flat panel
- Placing / Mounting
- Wall-mountable
- 40"-60"
- Max Load Weight
- 90.8 kg
- Designed For
- Peerless OneMount Flat Panel Modular Wall Mount ONE-TP , Peerless PARAMOUNT Universal Flat Wall Mount PF640, PF650, PF660 , Peerless PARAMOUNT Universal Tilt Wall Mount PT640, PT650, PT660 , Peerless SmartMount Universal Flat Wall Mount SF640, SF650, SF660 , Peerless SmartMount Universal Tilt Wall Mount ST640, ST650, ST660
