Peerless-AV Articulating Arm Wall Mount 39-75" LCD
Quicklinx: CQRBWS00 Mfr#: PA750
£177.76 ex VAT
£213.31 inc VAT
The Paramount series wall mounts provide versatile and multi-functional features. With PA750, extend the display up to 21.35" (542 mm) or fully-retract it to just 3.00" (76 mm) from the wall for the perfect viewing angle. The Hook-and-Hang system offers easy, one-person installation of the display. A ratcheting handle provides locking tilt capability for quick adjustments to the amount of tilt, reducing glare and optimizing the viewing angle. Integrated cable management protects, contains and conceals cables for a clean installation.
Peerless-AV Paramount PA750 mounting kit - for flat panel - gloss black
Mounting kit
Mounting Components
Articulating wall mount
61.9 cm x 7.6 cm x 42.5 cm
Adjustable Depth
7.6-54.2 cm
Tilt
-5° to 15°
Adjustments
Roll, tilt, swivel
Recommended Use
Flat panel
Recommended Display Size
39"-75"
VESA Mounting Interface
Up to 600 x 400 mm, from 200 x 100 mm
Max Load Weight
45.4 kg
Gloss black
5-year warranty
61.9 cm
7.6 cm
42.5 cm
Adjustable Depth
7.6-54.2 cm
Gloss black
AV Furniture
Mounting kit
Mounting Components
Recommended Use
Flat panel
Cable Management
39"-75"
Tilt
-5° to 15°
Adjustments
Roll, tilt, swivel
Max Load Weight
45.4 kg
Limited warranty - 5 years
Brand: Peerless-AV
