Peerless-AV Articulating Arm Desktop Mount for 12-30" Displays
Quicklinx: 9Z37WS00 Mfr#: LCW620A
£113.64 ex VAT
£136.36 inc VAT
The 620A series is a single display mount with a flexible arm that increases productivity by freeing up desk space with more efficient display positioning. Installation is quick and easy, and secures a display with a quick release mechanism. Instantly set the height of the display by raising or lowering it 12.6", extending up to 22", and tilting forward and back. Furthermore, the LCW620A can pan and rotate for comfortable portrait or landscape viewing.
Peerless 620A Series Wall Mount LCW620A mounting kit - for LCD display - black
Mounting kit - wall-mountable
Mounting Components
Articulating arm, wall mount
Adjustments
Pan, tilt
Recommended Use
LCD display
Recommended Display Size
19"-30"
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm
Max Load Weight
9 kg
AV Furniture
Mounting kit
Mounting Components
Recommended Use
LCD display
Placing / Mounting
Wall-mountable
Cable Management
Integrated cable management
19"-30"
Adjustments
Pan, tilt
Max Load Weight
9 kg
Adjustable height, rotating, portrait to landscape movement, swivel adjustment
Brand: Peerless-AV
